So I bought a 2019 Durango RT Hemi over the winter. It had 60k miles on it and runs excellent. Typically after a vehicle purchase, first thing I do is change oil. I came home and swapped in Mobil 1 and a Wix. Mobil 1 is what I’ve always used and never had issue. Well, after this switch, it sounded like a transplanted a 12 valve Cummins. Real noisy and clackity. I called the previous owner and asked what oil they used because it was quiet when I bought it. Valvoline. So, I drained the Mobil 1, swapped in Valvoline Advanced 5w20 and it’s quiet once again. When it’s cold, it will be semi noisy upon startup but go away after less than a minute. Now that it’s warmer, it’s quiet from startup as well. My question is, should I move to a 5w30 when it starts getting cold again? Also, I’ve obviously become a Valvoline fan, I’m assuming the moly content is what has helped, but should I use Valvoline Restore and Protect in the meantime? It now has 64k miles and I’d like to keep it as long as possible. So many guesses as to the reasoning of the hemi tick from poor design, small needle bearings, MDS etc. This one isn’t the manifold bolts and I believe it could be due to the needle bearing design from my research as well. Would 5w30 benefit in the warm weather? Should I go dramatic and move to 0w40? My thought is the Valvoline Restore and Protect may help keep build up off the needle bearings as well? Any input?
