Originally Posted by pleopard
Originally Posted by Cellist
Recently purchased a 2020 4 door corolla SE 6-speed and I have exact same feeling as OP does. It's embarrassing and annoying when driving in slow and heavy traffic and you need to down-shift to 1st gear! I've also test-driven a Jetta manual and it shifts way better.
I guess this further suggests this specific concern may be normal. What about 1st to 2nd shifts when cold? Do you find that they're harder and rough?
Yes, I feel it's normal for this car. Maybe a bad design. It's also has a long shifting throw. I've also test-driven a civic (LX manual) and a Jetta and the civic. The civic gearbox is even rougher than the corolla. The Jetta is the smoothest.
1st to 2nd needs some extra force and no problem when shifting after 3 or above . I was annoyed quite a bit when I first got the car and was considering a fluid change. But after some research, I think I'd accept this for now because:
1) Toyota uses s 75w monograde (not a 75w-85) fluid which is already very thin and looks pretty solid in add pack according to the VOA.
2) Hard to find a reasonably priced replacement fluid with better low temp performance (perhaps Rredline MT-LV but it's about $20/qt)
