Isn't the 2018 the first year of the zf8 wrangler? If it is equipped with the zf8 you could use maxlife if you want. Many have used it without issue however that was the older version of maxlife one which is this
https://greatoceanauto.com.my/wp-content/uploads/2021/10/Maxlife-Multi-Vehicle-ATF.pdf
This is the new one which includes some cvt's but still lists the zf8 but i wonder how that affects clutch life in the long run. It makes me weary of using this in a step shift and even in a cvt I don't think I'd use this instead of pure cvt fluid or castrol transmax as maxlife is a thin cvt fluid at 5.9. Castrol transmax atf/cvt is different as it's notably thicker and closer to older generation atf and current cvt's with it's viscosity of 7.1cst
https://sharena21.springcm.com/Publ...2d889bd3/5ca3517a-e29c-e711-9c10-ac162d889bd3
Here's a post where this was discussed. It talks about the afton additive pack being thoroughly tested and all that but it's still a bit concerning.
