Gat a few more quotes and post them back here for our review and criticism.
The one we have at work failed around 55k. Now the 6R80 in the 2017 is shuddering and squawking during shifts. It has just over 100k. These are also heavily loaded and not used gently. After riding with the one guy a couple times, I'm not sure how they got 14 years and over 250k miles out of the previous 2 2004 Chevy's (this is another local surveying company my boss bought out).I know. You'd think people would have the sense to flush and fill the fluid at 60K, but they trust Ford marketing instead.
4L65 or 4L80?After riding with the one guy a couple times, I'm not sure how they got 14 years and over 250k miles out of the previous 2 2004 Chevy's (this is another local surveying company my boss bought out).
Are there any specialists in the area that deal with this type of vehicle constantly and could get you a better deal?130k on this van, quote from the Ford dealer is $7,200 for a replacement transmission, seems awfully high. Thoughts? 3.5 EB V6.
The 10R80 in the '21 in my sig had a fluid flush at 60K (had to be done at the stealer with a heated flush machine, ATF was BLACK), didn't help it a bit. We had one down for 4 months, couldn't get the parts for it, now mine is getting worse at 85K, and we have several others going at under 100K. The 6R80s were almost bulletproof, except the flimsy TCCs.I know. You'd think people would have the sense to flush and fill the fluid at 60K, but they trust Ford marketing instead.
$7200 is less than I was quoted for mine, stealer quoted $9K.Are there any specialists in the area that deal with this type of vehicle constantly and could get you a better deal?
I had a 4L80E tear out the OD sprag around 120K (stupid company getting 3.08 rear axle ratio on a work van did that). Our 6L90s have been OK so far... (knocking on wood)4L65 or 4L80?
I know some of the 4L60/65's could be a gamble, some doing high miles and some... not... not trying to poke sticks at GM. But I believe the 4L80 is a bit more stout, hence the question.
4L65 or 4L80?
Don’t these take Mercon LV? That’s a normal characteristic as soon as the fluid has a few thousand miles. There was a bulletin when that fluid came out.ATF was BLACK
Here is the tsb you speak of....however those years 2008-2010 specifically were years that the transmissions failed quite frequently (at least on the escapes). I remember we had a fleet vehicle in that year range with black fluid at like 60k and I called the fleet company for authorization to change the fluid and he told me that there was no point in changing the fluid on this one... because it will have to be replaced anyway. He said every single one of those failed on them so they no longer bothered maintaining them.Don’t these take Mercon LV? That’s a normal characteristic as soon as the fluid has a few thousand miles. There was a bulletin when that fluid came out.
What is your criteria for disposal? Repair cost > ACV?Thanks guys, I had a little bit of sticker shock but sounds like this isn't a ridiculous price. I guess I'm sending another to Copart.
It's been checked recently and the color is still normal, been about 25K miles now. The 10R80 is the "Linda Blair" of transmissions-they literally act like they're possessed. The colder they are, and the more they're babied, the worse they act. Get them hot & take the whip to them, they get (somewhat) better.Don’t these take Mercon LV? That’s a normal characteristic as soon as the fluid has a few thousand miles. There was a bulletin when that fluid came out.
Might want to check the price of a new one first-ours sticker in the $50,000 range!Thanks guys, I had a little bit of sticker shock but sounds like this isn't a ridiculous price. I guess I'm sending another to Copart.
Sounds like my wheel time with a 2013 Focus with the lousy DPS6 Powershift DCTIt's been checked recently and the color is still normal, been about 25K miles now. The 10R80 is the "Linda Blair" of transmissions-they literally act like they're possessed. The colder they are, and the more they're babied, the worse they act. Get them hot & take the whip to them, they get (somewhat) better.
The 10R80 is also spec'd for Mercon ULV, not LV. Thin vs. thick debate, anyone?It's been checked recently and the color is still normal, been about 25K miles now. The 10R80 is the "Linda Blair" of transmissions-they literally act like they're possessed. The colder they are, and the more they're babied, the worse they act. Get them hot & take the whip to them, they get (somewhat) better.
I have about 30 vans in the fleet, about a 50/50 mix between Connects and fullsize Transits. This is the first transmission we've lost. In fairness, these are work vehicles that probably aren't treated the best and have a full payload. Sent a 2022 Connect with 88k to the auction a few weeks ago, head gasket was leaking and the dealer would only do a long block.
Previously had Expresses and E-series, they were good for 300k+, not sure the Transits will make it anywhere near that.
Still weirded out seeing a VIN that starts with an N.
That's amazing that the truck has those amount of miles with the CDF defect.And there are also transmissions that fail due to lack of fluid change......just so ya know. I'm quite familiar with the Ford ten speed transmissions as two family members have them, one of those has almost 190K on it with no issues. (They also flush the fluid every 60K).
Need the first two digits to figure it out.What does the N mean ?
