With D-4S on your V6, my recommendation would be HPL 10W20, durable OF and one year OCI, probobly in the Spring. Keep it simple and methodical.
One cannot distinguish between mechanical shearing of the VII and fuel dilution in a Blackstone analysis.Shearing is down considerably with these-2 name brands (5w30 SP / GF6), versus the SN+ UOAs of 2019-2022.
I'm guessing the timing belt is a happy camper too.
Curious.... how many quarts does this 3.5 V6 hold?
You’re getting fuel dilution. The higher viscosity is a good idea, given your particular circumstances.Latest report. Trying to get a good trend going. Sample taken cold. Fe dropped quite a bit which is good. This is with standard M1 5W-30. I switched M1 0W-40 FS for S&G from this change and will do another analysis. I may switch back depending on how it goes.
I sampled cold which I think is the fuel dilution issue. I drive 90% highway about 35 miles each way to work so not sure what else could cause it other than the cold sampling.You’re getting fuel dilution. The higher viscosity is a good idea, given your particular circumstances.
I see evidence for fuel dilution in almost every sample. Look at the low viscosity and flash point numbers across the board.I sampled cold which I think is the fuel dilution issue. I drive 90% highway about 35 miles each way to work so not sure what else could cause it other than the cold sampling.
The last few samples were taken cold. What else could cause the issue? I don't idle very much. My only thought is fuel getting in the oil the few minutes it takes the pull the Taco into the garage while its cold.I see evidence for fuel dilution in almost every sample. Look at the low viscosity and flash point numbers across the board.
Direct injection engines are prone to it. How frequently do you take long highway trips? If you don’t do a good long highway jaunt that frequently, you’re probably going to have fuel in your oil.The last few samples were taken cold. What else could cause the issue? I don't idle very much. My only thought is fuel getting in the oil the few minutes it takes the pull the Taco into the garage while its cold.
Every day, approx. 35 miles each way on the highway. Not slow eitherDirect injection engines are prone to it. How frequently do you take long highway trips? If you don’t do a good long highway jaunt that frequently, you’re probably going to have fuel in your oil.
I’d definitely stick to the oil selection and regimen you’re doing then. What octane fuel do you use? Are you using a tune by chance?Every day, approx. 35 miles each way on the highway. Not slow either![]()
Probably this. My usual process when I know I'm going to take a sample is to have the ramps in place, then go for a ~30 mile drive, no stops, then when I get back home, drive right up the ramps. Shut the engine off, then drain and sample.The last few samples were taken cold. What else could cause the issue? I don't idle very much. My only thought is fuel getting in the oil the few minutes it takes the pull the Taco into the garage while its cold.
87 oct. No tune, but have been thinking about getting an OTT tune though.I’d definitely stick to the oil selection and regimen you’re doing then. What octane fuel do you use? Are you using a tune by chance?
If you're not worried about fuel dilution, then have at it.87 oct. No tune, but have been thinking about getting an OTT tune though.
