2018 Ram 1500 5.7 Radiator Recommendation
Space Coast
Hello, BITOG
Today, I noticed a coolant leak coming from the upper radiator on the driver's side. The leak is not significant, but it's noticeable. I intend to order a replacement from Rock Auto from the list provided below. Does anyone have experience with these?
Thanks in advance,
I tried this and failed because my car is so old and obscure and has no aftermarket support, but if I were you and in the market for a radiator, I would look for a seller that sells all-aluminum radiators that fit your application. Most of the stuff you're looking at on RockAuto comes out of the same factory in China. All-aluminum will always be superior to the plastic/ aluminum units sold at RockAuto, AutoZone, etc., assuming a reputable manufacturer.
I'll look into that. Thanks,
I just put a CSF 3572 in an '06 Ram 1500. I give the fit a "B" because I had to further slot the fan shroud bolt holes to get it to fit.
There's really no excuse for that, but at least it fit the body well and it was just a fan shroud issue.
I also swapped in a shorter fan shroud bolt on the RH side because it was going to lightly contact the plastic side tank when fully seated:
I also swapped in a shorter fan shroud bolt on the RH side because it was going to lightly contact the plastic side tank when fully seated:View attachment 247291
There really isn't any excuse for that.
The bolts in my 2018 lined up without issues.
