P0300 is the only code you have?
Can you get the freeze frame data?
Without that info and a proper diag, any info provided is a guess at best.I don't believe I can with my handheld. Perhaps my HP Tuners could.
The P0300 is the only code. I've checked what is pending several different times and it's the only one that shows up in Pending or as the CEL code.
I didn't have much luck on the Wrangler forms but looking on the Gladiator forums, which has all the differences a JL would over a JK, this seems to be a rampant issue. There is a 100+ page long thread there on the "dreaded misfire code". https://www.jeepgladiatorforum.com/forum/threads/survey-for-those-with-misfire-issues.24853/
PCMs are being reflashed/replaced. Cams are being replaced etc.
Are you in a position to do a full diag yourself?
See BITOG where thicker oil will prevent that …
I don't think he has a dead cylinder; most likely misfires across multiple cylinders.Like @Danno says, there's tons of youtube videos out there where people fire the parts cannon at their pentastar replacing coils, spark plugs, injectors, etc, when it's a mechanical problem causing a dead cylinder.
Sorry if I missed it, but If you crank the engine over in clear flood mode can you hear the cadence of a dead-ish cylinder?
If you do a scope/scan with an amp clamp knowing the firing order, this will pinpoint the dead cylinder as you're cranking it over. Like said, usually it's a rocker arm problem causing loss of compression in one or more cylinders.
I don't think top end parts are all that expensive or hard to come by for pentastars. A bit of labor of course. If it does need to be torn into and she wants to keep this vehicle, I'd invest in one of those Doorman all aluminum oil cooler/filter housings and swap that out while they're right there.
I wouldn't think the vehicle would be usable if one whole bank was dropping out even intermittently.
I don't stock multiple heads for nothing so I will concur with this statement.I don't think he has a dead cylinder; most likely misfires across multiple cylinders.
I think if he goes into the misfire counters he will probably find 3 cylinders on one bank to be affected. If I had to load my parts cannon, it needs a new head.
Yep I watched that one too. I'd be curious to know if it's a head problem (crack, etc) or a valvetrain problem though.I don't stock multiple heads for nothing so I will concur with this statement.
I watched a video by Pine hollow diagnostics on YT yesterday diagnosing a missfire on a grand caravan with the same ERB engine code. Needed a head after doing a clear flood with live data which I believe was pico scope. You could hear the lack of compression as it cranked. If its not ticking anymore than normal valvetrain sounds a head would be my guess.
OP - Looking at your story, it seems you got a hold of a service advisor with a poor attitude. Regardless, if its under power train just let them fix it. Chrysler techs see so many of these ERB 3.6s its pretty easy for them to diag unless there a newbie maybe. I can check warranty status if you want to PM me your vin btw.
My '19 has always idled rougher than I thought it should, even when new. As I recall every 3.6 I drove was this way. Just funny you mention it 'cause even if it's normal, I concurHa, parts canon.
Cam lobe(s) would make sense, if it's not totally wiped out and lifting enough to run ok in most driving situations.
The first time I was in this Jeep, before this CEL issue, I asked "does it usually idle like this?" Its rough enough to make you wonder but not enough to say there's a problem. But then I thought "Chrysler Corp" I remembered years ago being in a new Jeep Liberty when the 3.7 came out and thinking that idled rough, turned out to be "normal"
If I cup my hand over the tailpipe there's no detectable miss.
Supposedly the JL's don't need this/have a different setup. Dorman doesn't list their part to fix the '18+ JLLike @Danno says, there's tons of youtube videos out there where people fire the parts cannon at their pentastar replacing coils, spark plugs, injectors, etc, when it's a mechanical problem causing a dead cylinder.
In the video at the 7:51 mark , he describes the application and different Pentastar generations. Basically the Dorman housing is designed for the GEN 2 but will also fit the early Gen 1 applications if you have a Gen 2 oil cooler to attach. The JL is the latest Pentastar "Upgrade" Gen 3 series and Dorman does catalog it for either Gen 1 or Gen 3 Pentastars because the oil cooler that sits on top is different between all 3 Gens but only designed for the Gen 2 engines.
It has not been proven out the Dorman housing will fit the JL. (Gen 3)I'm not being a smartaz and likely I'm just a dumbaz but I'm not following you.
I've watched that vid before and based upon the 7:51 mark it would seem it doesn't fit.
I'm also not understanding
"The JL is the latest Pentastar "Upgrade" Gen 3 series and Dorman does catalog it for either Gen 1 or Gen 3 Pentastars because the oil cooler that sits on top is different between all 3 Gens but only designed for the Gen 2 engines."
I guess really all that matters is: are you saying the Dorman part fits JL's? Y or N?
