This is where it sits in relation to AC condenser, mounted to brace in front. That is behind the lower bumper grill. If driving it does help bring it down with the normal airflow but even with AC on and fans going, slow traffic just not enough.
Yep, those temperatures require cooler, radiator cooler.The ‘16+ Pilot’s did not come with one. It was a Honda option to add at dealer, yourself etc. I added one to mine, I don’t know if stmech did. It helps but also depends on overall transmission. He has 6 speed like me, there are TSB’s for torque converter IF you meet the criteria or dealer can advocate etc.
I want to get a larger cooler but the one I’ve been searching for is unobtanium from Long Manufacturing, one of their Tru-Cool Max that would fit nice with hose barbs in correct place. I don’t feel that the factory one gets enough air pulled through from the fans when stuck in slow crawling traffic. I only tow a small 5x8 utility trailer that weighs 840lbs empty. Heaviest I recall loaded was about 2200 lbs on scale so 1400 load inside. My highest temp (255F) was actually empty trailer, crawling bumper to bumper followed by many stop signs and small hills.
I wasn’t going crazy with cooler as I wasn’t sure I’d be keeping the Pilot due to tranny concerns. It is currently at Honda dealer getting a new TC (and brake master cylinder/booster). Once I get it back I’ll focus on a larger cooler. Sadly so many people don’t know how bad it actually gets just doing around town and slow traffic trips, not towing. I hit 244F with just myself, wife, stuff in back of SUV to go to VA to visit my son. VERY slow crawling traffic through NY for 4 hours on a mid 80F day.
I see. I mean if it is hovering around 255f, that is definitely not sufficient.This is where it sits in relation to AC condenser, mounted to brace in front. That is behind the lower bumper grill. If driving it does help bring it down with the normal airflow but even with AC on and fans going, slow traffic just not enough.
Doesn't hover there, that was peak spike very slowly dropped once on more level with air flow not as many stops. Highway drives as long as moving it slowly drops to more normal 190's but definitely takes a while. A couple stops signs and it's climbs quickly.I see. I mean if it is hovering around 255f, that is definitely not sufficient.
For example 2nd generation Tundra will do 245-250 through Eisenhower tunnel here in CO. But that is towing 5,000lbs over 11,000+ft altitude. That is one without radiator cooler. Chevy with cooler will go 210f.Doesn't hover there, that was peak spike very slowly dropped once on more level with air flow not as many stops. Highway drives as long as moving it slowly drops to more normal 190's but definitely takes a while. A couple stops signs and it's climbs quickly.
I know who you are talking about regarding 5W-30! Anyway, I just got a jug of Valvoline Restore and Protect 5W-30 at WM and will do the change before our trip. Our Pilot does have the Honda auxiliary ATF cooler.@STMech - do the 5W-30 Valvoline Restore and Protect, be confident, it's a good choice.
After your trip post back if you noticed anything different (I say you won't). Then you can post it back on Piloteers as we know at least one that repeatedly shares how much performance he lost and how horribly sluggish it was when he went from 0W-20 to 5W-30 and ditched very quickly. I'm not him so YMMV. In my daughters '08 CRV, using a 5W-40 diesel oil to me did feel like it lost some performance. That motor with not much HP is probably a bit tired with 248k so even a slight extra drag doesn't help to much. I replaced it with Valvoline Restore and Protect 5W-20 and it revs a bit more freely IMO.
My Pilot will stay on 5W-30 Valvoline Restore and Protect for the foreseeable future with 5k changes to get the fuel dilution out.
Twin Cities, Minnesota. We’re camping along the North Shore of Lake Superior for the fall color. No real mountains, but plenty of hills from Two Harbors north.5W30 has higher HTHS (look around for explanation). That will definitely give you more protection margin if your oil temperature during towing gets high. I would definitely feel warmer around the heart having 5W30 and towing. That is the easy part.
But I would really like to know where is my transmission fluid temperature. That is where towing problems are. Get some OBD where you can read both engine oil and transmission fluid temperature.
Where do you live? Are you towing over mountain passes?
Hills are fine. Altitude is real issue when towing as air density is low, so cooling is way less efficient.Twin Cities, Minnesota. We’re camping along the North Shore of Lake Superior for the fall color. No real mountains, but plenty of hills from Two Harbors north.
The Pilot has been running great on the 0W-20, we will give the thicker oil a test.
I know the thread is for the Valvoline Restore and Protect 5W-30 and we dove to the transmission. Do you have a scangauge or a different OBD2 plug in to setup and monitor transmission temperatures? On wife's Pilot I put a USB charge port on left side of steering wheel and a USB extension cable that goes to center console to plug in to aux port. This way I can just charge my phone or use the extension and display on radio screen/carplay.Hills are fine. Altitude is real issue when towing as air density is low, so cooling is way less efficient.
But I would still pay attention to transmission temperature.
I do not have a direct monitor of ATF temps. It's something that I have thought about. Have you had any luck using the Torque app? I tried to set this up way back on my 2003, but I don't think that the old Pilots were capable of linking that info.I know the thread is for the Valvoline Restore and Protect 5W-30 and we dove to the transmission. Do you have a scangauge or a different OBD2 plug in to setup and monitor transmission temperatures? On wife's Pilot I put a USB charge port on left side of steering wheel and a USB extension cable that goes to center console to plug in to aux port. This way I can just charge my phone or use the extension and display on radio screen/carplay.
Most of my trips I have the phone in the iOttie as shown, Pandora playing on radio from it, Waze navigation showing/speaking on car radio screen and OBD Fusion monitoring my temperatures. My VCM is still currently enabled so the cyl showing for my own reference.
@edyvw from before- Pilot from factory does not have any in radiator trans cooling, just whatever hockey puck version. Add on factory or aftermarket is only options.
View attachment 301188 View attachment 301189
I wish we’d sticky a post about Blackstone…I used to use the Torque app when I had Samsung phone but when I went to iPhone I don't think it was available in app store. I've had OBD Fusion since then, I think I got the paid version, not sure if a free one. My cars all now have a VeePeak BLE+ in glove box (or plugged in) and all family has OBD Fusion on phone. My son and daughter help others with theirs.
Not hard to setup and you can pick gauge styles etc. I had to put the PID's in for transmission and one or two others. Not hard, we can help, I think I got the original details from Piloteers or Ridgeline Owners Club.
Also from all here at BITOG and my experience. Don't use Blackstone if fuel dilution is a concern and you want accurate info. Wear metals, viscosity on my tests were fine and comparable but fuel dilution was way off between Oil Analyzers and Blackstone. Oil Analyzers use gas chromatograph for the dilution. I posted one of mine in the used oil thread that had sample pulled at same time. One went to OA, one to BS. https://bobistheoilguy.com/forums/threads/blackstone-vs-oil-analyzers-pp-euro-l-5w-30-5175-miles-19-pilot-67k-miles.392379/post-7154176
Yes but VRP does not have a HTHS rating of 3.5 or greater as majority of 0w40 oils do (Euro Spec). Would I use VRP as an everyday oil at a 5000 mile drain and refill oil with outstanding cleaning abilities? Yes.But not Valvoline Restore and Protect !
You switch from Amsoil XL to SS? (Just noticed your signature.)Disable the VCM, keep all cylinders firing. Transmission cooler and ditch the DW1 transmission fluid if you have the six speed. I run Amsoil blue cap ATF in the 19 six speed. The engine gets Amsoil SS 0W30. I follow the olm. OCI is about 5500-6500 miles.
