Break-in is surprisingly low for metals, honestly. How many OCIs have been done? Just the one to switch over to Amsoil?
I have a slew of UOAs on this engine; my interest level is high because I now own two of the same (now own 2 2018 Taurus SEs). These engines wear extremely well and don't need anything expensive to offer a long life cycle. Generally 10k mile OCIs are easily doable from the data I've seen.
These engines suffer from a design concern in that the water pump is internal (inside cam chain cover) and if the outer shaft seal leaks, it will put coolant into the lube via seeping into the pan (obviously a bad thing). Even if it leaks externally via the weep hole, it's not a small deal. The pump R&R is about a 15 hour job; most places quote $1500 or so. Some folks have had bad luck; seeing the pump go as early as 60k miles. Others have had really good luck with the pump lasting 200K miles. Seems to be no rhyme or reason to how long they will last. Because of this, I believe that UOAs are critical to saving the engine; watching for coolant is a major thing. The difference being that if you can catch the issue PRIOR to coolant getting into the oil, you're going to spend $1500. if it gets in and causes severe oil degradation, you'll ruin bearings and cylinders; time for a new engine. YT is full of vids regarding this topic.
Honestly, UOAs on this engine are pretty much useless except to track for coolant. There's never going to be any wear issues whatsoever. I'm considering just starting my UOAs around 50k miles, watching for the impending doom of coolant pump issues. You'll never see any definitive wear shift due to lube selection in these engine; they show no preference for brand/grade. Simply put, lubes don't kill or save this engine. The only savior for the engine is knowing if/when the pump is going to turn the lube into molasses.
