- Joined
- Mar 20, 2023
- Messages
- 4
Have reviewed many posts on this site as well abroad and have come to some insight on possible ideas to help clarify a few things.
The PTU in the 2017 Ford Explorer XLT 3.5 Duratec has no water cooling. Currently the vehicle has 81,000 miles/130,000 kms. The fluid has been changed out partially 5 previous times, but was never successful in getting out all of the fluid. It would average around 430 ml. No leaks from the PTU.
Many on the forums state that the PTU only holds 17.9 fl oz (0.53L) or 530 ml. as well as in some owners manuals. The 2017 Ford Explorer owners manual published on April 2016 states the PTU's capacity is 23.7 fl oz (0.70L) or 700 ml. - see attached pictures. That is a difference of 32% more fluid. I am sure that would help with some more cooling and lubrication. As well, the capacity of 700 ml is the same for all three engine options. - 2.3 eco-boost, NA 3.5, and 3.5 eco-boost.
Also noticed that the Magnetic fill plug was not getting enough splash onto the plug and therefore not picking up any metal pieces etc.
This unit has the extended vent tube and I did the mod of extending the hose up to the top of the engine compartment. Secondly, I install a 1/2 20 self tapping oil drain plug on the bottom of the PTU - see picture.
Having drilled the case and capturing all the gear oil in the pan, I recovered about 520-530 ml. The fluid was flush with the fill plug. So next step was to install the drain plug, leave the fill plug out, and start filling the PTU through the vent tube. with the fill plug out it fills what turns out to be about 530 ml before it started to drain out of said fill hole.
After installing the fill plug and a little bit of further thought on the matter, I decided to put a further 170 ml into the PTU bring it up to 23.7 oz/700 ml.
Because the Fill plug is back in, it takes much longer to add the 170 ml. Time and patients or you can get the plunger and help matters along. Just take it easy when "forcing" the fluid in.
Your other option is after you drain the PTU to drive the passenger wheels on ramps. and see if you can add the extra 170 ml because the fluid would run to the drivers side an hopefully give you the extra room to add the 170 ml before it runs out of the fill hole.
Lastly and importantly, I read on this site (from metroplex) that as of June 2016, Ford changed the gears which reduced the side load of the idler gears from walking into the case. This of course would cause even more heat and friction and eventually burning it up quickly.
I am going to change out the fluid within 12,000 miles/20,000 kms to see how everything looks and post my findings. I am currently using Redline 80W140.
Cheers
Cheers
