2017 F150 2.7l DIY Bypass
Houston,TX
Yesterday I finished up on my Bypass build.
Used a Wix 24755 housing and a Wix 51050 Filter.
Built a manifold from 1/4 npt brass fittings. In the Hose barb leaving the manifold I tapped for 1/8 npt to install a restriction plug. .032 hole.
took a sample before running the bypass and will report back after 500 miles with new PC results.
@ 59 hours /40548 miles
PC 21/18/13 >4= 17281/ >6 = 1625 / >14 = 43
@ 82 hours /41415 miles
PC 22/18/13 >4 = 21268 / >6 = 1933 / >14 = 74
I am interested,,,what is the filter element rating ? We used them on forklifts that had bypass filters .
My B164 came in yesterday. I will be posting PC results after the holiday. By then i should have enough miles to see a valuable change. would be nice to find a little better filter without having to go to the Amsoil. don't care for the idea of $50 a pop.
What would be really impressive is if you could tie the results of these PCs to UOA data.
IOW - show that the effort actually pays a dividend in wear control, not just particle control.
Don't talk to me about theory; show me da money!
Is this good enough data for ya.
I'm running my samples in house, the only data i don't have access to is getting a proper fuel dilution.
these are current samples and a VOA. next sample will be with the bypass running.
Code
Sample Date Oil Ref 11/19/18,11/6/18,10/24/18
Sample # 39993 39942 39907
Lab #
Analyst
Unique ID 39993 39942 39907
Wear Status 0 0 0
Cont Status 0 0 0
Chem Status 21 0 21
Unit Usage 1157 1134 1108
Oil Usage 82 59 33
Oil Added
Aluminum 1.52 6.65 4.02 3.58
Antimony 0.45 0 2.01 0.92
Barium 0 0 0 0.02
Boron 84.04 65.97 58.31 61.5
Cadmium 0 0 0 0.02
Calcium 1,073 1,558 961.8 822.8
Chromium 0 0.36 0.14 0.11
Copper 0.04 2.02 1.29 0.89
Iron 0.8 13.2 8.7 6.3
Lead 0.08 0.29 0 0
Magnesium 499.24 1,107 506.12 461.14
Molybdenum 78.76 118.93 75.58 74.09
Nickel 0.09 0.24 0.06 0
Phosphorus 653.37 989.31 723.95 705.36
Potassium 0.14 1.43 0.98 0.8
Silicon 4.6 16.19 11.81 17.24
Silver 0.01 0.04 0.03 0.02
Sodium 7.99 3.03 2.28 9.73
Tin 0.06 0 1.97 2.37
Vanadium 1.66 2.99 1.42 1.58
Zinc 1,025 1,725 914.11 906.63
Manganese 0.02 0.49 0.25 0.15
Titanium 0.03 0.39 0.01 0
Add Depletion 68 64 70
Ferrous Idx
AntiOx Deplete
Antiwear Comp
Free Water
MxD Ct >20 6 4 5
MxD Ct >25 3 2 4
MxD Ct >50 0 2 0
MxD Sl >20 4 5 10
MxD Sl >25 3 4 9
MxD Sl >50 0 1 2
MxD Ft >20 21 6 37
MxD Ft >25 9 4 23
MxD Ft >50 2 1 4
MxD Ox >20 20 14 31
MxD Ox >25 16 14 23
Cnts >4 21,268 17,281 13,687
Cnts >6 1,933 1,625 1,788
Cnts >10 117 101 264
Cnts >14 74 43 104
Cnts >18 30 23 55
Cnts >22 22 19 36
Cnts >26 16 14 17
Cnts >32 8 14 13
Cnts >38 6 7 8
Cnts >56 3 5 2.5
Cnts >70 1.9 2 1.2
ISO >4 22 21 21
ISO >6 18 18 18
ISO >14 13 13 14
Glycol Vol 0 0 0
IR Fuel
IR Oxidation 7.77 11.47 10.7 9.75
IR Soot
IR Nitration 4.72 16.16 13.6 10.96
IR Water
IR Hcarbs
IR Glycol
IR Anti-Wear
IR Sulfation 16.62 19.07 18.55 18.13
Visc 40C 66 55.8 60.2 56.5
Visc 100C 11.7 10.2 10.8 10.3
Visc Idx 172
MxD Ox >50 7 6 2
Total Acid
Total Base 6.87 4.12 4.54 5.07
Foam Tend 1
Specific G. 0.855
Solids Vol
MxD Ot >20 3 1 2
WDA Severity
Ferro Large
Ferro Small
Fuel Vol
PC Vol < 6u 1.09 0.88 0.68
PC Vol 6-14u 0.4 0.36 0.47
PC Vol >14u 0.91 1.17 1.15
Soot LEM/TGA 0 0 0
Soot Vol
MxD Ot >25 2 0 2
PPM Water 36 20 0
MxD Ot >50 2 0 1
Total Fe 11 0 0
Total Non Fe
Fe >21
Fe >25 0 0 3
Fe >50 0 0 1
Fe >100 0 0 0
Fe >38 0 0 2
Fe >70
Interesting ...
Metals tracked down to the tenth or hundredth? What kind of R&R does the equipment exhibit?
The wear metals are going up (most of them double?) in such a very short duration? And this is after the BP install?
This is confusing. Am i reading this correctly? These are PPM? Either I'm not following, or this is not impressive at all.
Key word in last line before the results.( next sample will be with bypass)
This is pre install with Mobil 1 5w30 and oem cartridge filter. Ill post up the initial tomorrow with first 200 miles of bypass. Just pulled the sample this evening.
Yes the metals are in ppm. Rotode spectrometer that reads in the hundredths. I just round to the nearest whole.
Well clearly I missed that !!! Sorry.
Look forward to the data.
Well, filter has already started to show improvements with only 125 miles. PC is down slightly so I'll continue on my normal 10% testing regiment. I'm not going to give too much reading into the spectrometry until it has more time to filter.
@dnewton3 Its all good. We all sometimes miss things.
Code
Sample Date Oil Ref 11/21 11/19 11/6 10/24
Sample # 40041 39993 39942 39907
Lab #
Analyst
Unique ID 40041 39993 39942 39907
Wear Status 0 0 0 0
Cont Status 0 0 0 0
Chem Status 21 21 0 21
Unit Usage 1163 1157 1134 1108
Oil Usage 88 82 59 33
Oil Added 1
Aluminum 1.52 4.05 4.35 4.02 3.58
Antimony 0.45 0.89 2.25 2.01 0.92
Barium 0 0 0 0 0.02
Boron 84.04 52.9 50.7 58.31 61.5
Cadmium 0 0 0 0 0.02
Calcium 1,073 947.72 980.03 961.8 822.8
Chromium 0 0.2 0.26 0.14 0.11
Copper 0.04 1.36 1.5 1.29 0.89
Iron 0.8 9.5 10.3 8.7 6.3
Lead 0.08 0 0 0 0
Magnesium 499.24 543.05 528.66 506.12 461.14
Molybdenum 78.76 73.36 74.95 75.58 74.09
Nickel 0.09 0.18 0.17 0.06 0
Phosphorus 653.37 739.71 735.68 723.95 705.36
Potassium 0.14 0.99 1.03 0.98 0.8
Silicon 4.6 10.8 11.69 11.81 17.24
Silver 0.01 0.04 0.04 0.03 0.02
Sodium 7.99 2.42 2.47 2.28 9.73
Tin 0.06 1.82 2.83 1.97 2.37
Vanadium 1.66 1.76 1.92 1.42 1.58
Zinc 1,025 872.13 893.55 914.11 906.63
Manganese 0.02 0.1 0.14 0.25 0.15
Titanium 0.03 0.29 0.29 0.01 0
Add Depletion 68 68 64 70
Ferrous Idx
AntiOx Deplete
Antiwear Comp
Free Water
MxD Ct >20 5 6 4 5
MxD Ct >25 5 3 2 4
MxD Ct >50 0 0 2 0
MxD Sl >20 5 4 5 10
MxD Sl >25 5 3 4 9
MxD Sl >50 0 0 1 2
MxD Ft >20 13 21 6 37
MxD Ft >25 6 9 4 23
MxD Ft >50 2 2 1 4
MxD Ox >20 18 20 14 31
MxD Ox >25 16 16 14 23
Cnts >4 12,928 21,268 17,281 13,687
Cnts >6 1,168 1,933 1,625 1,788
Cnts >10 104 117 101 264
Cnts >14 59 74 43 104
Cnts >18 28 30 23 55
Cnts >22 20 22 19 36
Cnts >26 14 16 14 17
Cnts >32 11 8 14 13
Cnts >38 6 6 7 8
Cnts >56 2 3 5 2.5
Cnts >70 1 1.9 2 1.2
ISO >4 21 22 21 21
ISO >6 17 18 18 18
ISO >14 13 13 13 14
Glycol Vol 0 0 0 0
IR Fuel
IR Oxidation 7.77 10.99 11.47 10.7 9.75
IR Soot
IR Nitration 4.72 15.36 16.16 13.6 10.96
IR Water
IR Hcarbs
IR Glycol
IR Anti-Wear
IR Sulfation 16.62 18.82 19.07 18.55 18.13
Visc 40C 66 53.6 55.8 60.2 56.5
Visc 100C 11.7 9.9 10.2 10.8 10.3
Visc Idx 172
MxD Ox >50 6 7 6 2
Total Acid
Total Base 6.87 4.22 4.12 4.54 5.07
Foam Tend 1
Specific G 0.855
Solids Vol
MxD Ot >20 1 3 1 2
WDA Severity
Ferro Large
Ferro Small
Fuel Vol
PC Vol < 6u 0.66 1.09 0.88 0.68
PC Vol 6-14u 0.26 0.4 0.36 0.47
PC Vol >14u 0.81 0.91 1.17 1.15
Soot LEM/TGA 0 0 0 0
Soot Vol
MxD Ot >25 0 2 0 2
PPM Water 47 36 20 0
MxD Ot >50 0 2 0 1
Total Fe 0 11 0 0
Total Non Fe
Fe >21
Fe >25 1 0 0 3
Fe >50 0 0 0 1
Fe >100 0 0 0 0
Fe >38 0 0 0 2
Final result with Wix 51050 element was a 20/17/12 iso count with 14.1 ppm iron at 187 hours on the oil.
Starting the test with a donaldson b5 =1000. I would at least expect some reduction in the PC
1000 mile report with the Donaldson p564967 Filter and Mobil 1 0w40
VOA showed 20/18/14 as the starting particle count
Looks like starting to make some progress. These are both the same oil just ran it twice to verify.
Code
Sample Date Oil Ref 1/30/2019 1/30/2019
Sample # 40445 40442
Lab #
Analyst
Unique ID 40445 40442
Wear Status 0 0
Cont Status 0 0
Chem Status 21 21
Unit Usage 47750
Oil Usage 46700
Oil Added
Aluminum 1.78 2.04 2.2
Antimony 0 0 0.47
Barium 0 0.02 0.01
Boron 277.25 229.97 238.81
Cadmium 0.26 0 0.17
Calcium 3,018 2,799 2,816.00
Chromium 0 0.11 0.15
Copper 0.04 0.61 0.59
Iron 1.3 4.8 5
Lead 0 0 0
Magnesium 23.12 104.43 105.41
Molybdenum 89.5 72.74 80.75
Nickel 0 0.28 0.21
Phosphorus 893.6 893.69 919.8
Potassium 2.03 1.84 1.73
Silicon 5.96 5.61 6.58
Silver 0.04 0.03 0.03
Sodium 3.58 5.22 4.93
Tin 0.36 0 0
Vanadium 2.1 1.95 2.44
Zinc 1,181 1,037 1,160.00
Manganese 0 0 0
Titanium 0 0.37 0.42
Add Depletion 80 76
Ferrous Idx
AntiOx Deplete
Antiwear Comp
Free Water
MxD Ct >20 6 5
MxD Ct >25 3 5
MxD Ct >50 0 1
MxD Sl >20 3 7
MxD Sl >25 2 5
MxD Sl >50 0 0
MxD Ft >20 6 13
MxD Ft >25 5 6
MxD Ft >50 1 1
MxD Ox >20 14 6
MxD Ox >25 14 3
Cnts >4 1,503 1,404
Cnts >6 285 290
Cnts >10 72 55
Cnts >14 36 32
Cnts >18 19 13
Cnts >22 13 5
Cnts >26 9 5
Cnts >32 2 3
Cnts >38 2 2
Cnts >56 1 1
Cnts >70 1 1
ISO >4 18 18
ISO >6 15 15
ISO >14 12 12
Glycol Vol 0 0
IR Fuel
IR Oxidation 11.53 14.32 14.29
IR Soot
IR Nitration 4.95 12.8 12.77
IR Water
IR Hcarbs
IR Glycol
IR Anti-Wear
IR Sulfation 34.27 33.08 32.71
Visc 40C 70.7 59 60.1
Visc 100C 13 11.3 11.4
Visc Idx 186
Total Acid
Total Base 12.61 11.56 11.5
Foam Tend 1
Spec Gravity 0.8456
Ferro Large
Ferro Small
Fuel Vol
PC Vol < 6u 0.07 0.07
PC Vol 6-14u 0.08 0.07
PC Vol >14u 0.22 0.17
Soot LEM/TGA 0 0
Soot Vol
PPM Water 0 0
Sadly, I admit to being utterly fascinated. I'm such a nerd! Thank you for the detailed results. Looking forward to more.
The only bypass filter I run is a 0.5 micron motorguard air filter, converted to oil. I use it on my Listeroid diesel genset. The engine has no filter at all and no pressurized bearings. Just squirt nozzles. So I tapped into the oil gallery and bypassed a little through the motorguard. The discharge lubes a bushing that is typically on the dry side. But, no data. Just a clunky old engine.
Thank you Cujet,
This is a fun little project for me, Im doubtfull it will prolong the motors life but its enjoyable to see the changes.
Side note
PC Vol is in PPM based on sump volume.
