Was getting misfire on 3 took it in after google search and positive for exhaust gases. They claim they are replacing it under warranty with no cost. My question is is the new engine revised in anyway? Ford techs ? Chris?
Was getting misfire on 3 took it in after google search and positive for exhaust gases. They claim they are replacing it under warranty with no cost. My question is is the new engine revised in anyway? Ford techs ? Chris?1.5 turbo i believe
We have been building cars for 100+ years. We know what works and what don't. No idea why they build stuff that didn't work in the past.Saw a vid by a Ford tech who explained this whole problem; question is why did they design it wrong in the first place?
Great description. When did they fix the slot? Why were the bores so close to begin with - thermal efficiency I presume?I'm guessing this failure is due to one of Ford's better ideas. That being the slot on the block head gasket surface, right between two closely spaced cylinders.
For those who don't know, old school head gaskets were compressible fiber gaskets, sometimes with a sealant around water passages, and a stainless fire ring around each bore. That fire ring DID NOT completely seal the combustion gasses, but instead was simply able to withstand the heat and pressure. The rest of the gasket surface was tightly compressed and was able to seal the gas pressure. When we started increasing boost to 30PSI or more, the gaskets could no longer contain the pressure and obvious signs of failure existed.
Fast forward to multi layer steel coated gaskets, and the fire ring was expected to seal 100%. What Ford did was reduce the sealing area to about 2mm between the combustion gasses and the water jacket, leading (some speculate) some movement of the mating surface, and to fast failure.
Yes, the new blocks are made differently, there is no slot between the bores (a drilled hole instead) and are far more reliable. In fact, I don't believe there are any cases of failure.
1.5Was getting misfire on 3 took it in after google search and positive for exhaust gases. They claim they are replacing it under warranty with no cost. My question is is the new engine revised in anyway? Ford techs ? Chris?
1 reason.....its cheaperWe have been building cars for 100+ years. We know what works and what don't. No idea why they build stuff that didn't work in the past.
