Oil ingress in BMW VVT sensor
The variable valve timing sensor (or what BMW calls the eccentric shaft sensor) on some BMW engines are prone to failure due to oil ingress in the sensor. The oil eventually fouls the connector, and there is even a TSB from BMW about the oil migrating through the wiring and damaging the ECU: https://static.nhtsa.gov/odi/tsbs/2016/MC-10151300-9999.pdf
Replacing this sensor requires removal of the valve cover, which is a bear of a job and can take up to 6 hours. Dorman sells a revised sensor under their "OE Fix" line, where they claim to address the original issue with ultrasonic welds, but the reviews are mixed: https://www.dormanproducts.com/p-77342-917-030.aspx
My stupid question is can't we just seal the sensor up with some kind of sealant to prevent oil from contaminating the internals?
Part number is 11377524879 if you are interested: https://www.fcpeuro.com/products/bmw-eccentric-shaft-sensor-valvetronic-11377524879
The structure is plastic with a metal plate. The Problem is, can the 4mm bolts hold proper tension….with plastic threads? How many miles on the engine?
A similar sort of problem occurs with Mercedes M271 engine and some other Mercedes engines. To prevent the oil migrating via the cable from the cam shaft adjuster to the ECU, an oil stop cable is available to insert into the cable harness.
I believe these are Hall affect sensors, and I believe that metal plate is the hall element itself - so there measuring the voltage in that plate, as created by the magnet on the end of the camshaft.
So your issue is you need to seal on the back side of that plate in order to keep it out of the connector. I doubt you can get the plate out without damaging it or the leads associated with it. Guessing only.
Possibly you could get a very thin layer of epoxy to seal the bottom of the connector housing? I doubt oil on the hall affect sensor would affect it - unless the amplifier is built into the sensor itself?
Does the new Siemens version not address the ingression problem? I personally would avoid a Dorman sensor on a job that takes 6 hours - but thats me.
The eccentric shaft sensor isn't a camshaft position sensor. It senses the position of the variable valve lift actuator shaft (which is just a camshaft but not one ran off the engine)
Have you confirmed whether BMW revised this part?
Fascinating. It looks like it's some kind of pigtail? Any idea how it works? Does it actually stop the oil from migrating further?
Thanks for clarifying. It's referred to as a VVT sensor in BMW TIS for whatever reason
Whicking up the cable is common in the industrial world, especially when we put sensors directly into high pressure hydraulic areas, like pressure or position transducers. The solution is typically to pot completely the back side of the cable, and sometimes a flow out epoxy on the front inside bottom of the connector itself.
Of course no automotive OEM would pay for this type of connector.
I assume the oil stop cable is some sort of intermediate cable that employs some of these features?
So here is my own 15 year old sample with 140k km. The gunk inside is some kind of gel that is not easily removed, so I think it's some type of thick conformal coating? My assumption is the coating degrades overtime and oil gets into the electrical bits.
Seems like a stupid issue that could be easily prevented? Wouldn't be a big deal if this sensor wasn't buried under the valve cover and pricey ($230 USD for OE).
And new vs old sensors for fun:
