2017 Chrysler Pacifica oil change
The Pentastar was designed for a 30w from the factory. Sometime around 2013, FCA changed its recommendation down to a 20w...my guess is for CAFE standards. I run a FS 5w30 in both of my engines all year long up here in MN.
If you are considering a 5w20...I would go with my favorite 0w20 and call it a day. Good luck.
Originally Posted By: wemay
Originally Posted By: Throt
Just because you don't live in a cold climate doesn't mean that 0w20 is a definite nope. The overall makeup of 0w oils is more often than not of higher quality than the 5w oils and there's no downside to using it. A 20 weight is 20 weight at operating temp, whether in 90 degrees or 20 degrees. I run 0w20 in Norther Ohio and I'll still run it when I move South later this year.
Agreed. No reason to disregard 0W-20 based on climate if you're considering 5W-20 too.
+1. The 0-20 I use holds up very well in all temps including the summer highs we see here 98-107F. Florida temps are not all that hot.
