I'm strongly considering the purchase of a new 2016 WRX, which, I'm quite sure most of you know, has the "FA20F" direct-injected, turbocharged engine.
Of course, I'm already fantasizing about the first oil change and what I should run. Subaru calls for a 5w30. They do authorize a "5W-40 conventional" for top-up purposes only, recommending a return to 5w30 at the earliest convenience (I know - there's no such thing as a 5W-40 conventional).
From everything I've read about Mobil 1 0W-40 here over the years, I have no doubt that it would perform very well...perhaps even extremely well...in the new WRX. And...it's available right across the street at Wal-Mart, at a decent price.
I haven't done a ton of research, but from what I have read, it seems that this engine has at least 3 factors that can be hard on oil:
1. Direct Fuel Injection (which, as I understand, can lead to fuel dilution of crankcase oil).
2. Turbocharger (the oil must cool the turbo and lubricate the turbo bearings, the high heat of which can lead to vaporization and shear).
3. Timing chains (shear)
From what I've read, 5w30s shear down very quickly in these engines. It would seem to make good sense to use something a bit heavier like a 5w30 that's a bit higher on the viscosity scale for that grade (perhaps a Euro formulation 30W), or maybe a 40W that is a bit lower on the viscosity scale for that grade (Mobil 1 0W-40).
I know that any oil will be a compromise...
And then I started reading about SAPS. Apparently that's a hot topic around here right now, especially in relation to the European turbo'd cars, especially?
Some seem to think that SAPS has a lot to do with deposits forming on intake valves on direct-injected engines, but then I was reading a recent thread here in which someone seemed to suggest that's not the case...
Anyway, what do you guys think the perfect oil for a new WRX would be? It won't be tracked - just driven in a spirited fashion mostly in the city, on the highway, and down an occasional crooked backroad with plenty of time spent in the upper reaches of the tachometer.
Oh, one more thing - I know Subaru calls for a 5w30. But that may not be the best choice for this engine in my application...especially going into summer.
