2016 ford fusion lug nut size and torque spec?
Are the lug nuts 19mm and torque spec 100 ft lbs? Tried researching on the internet that's what I found.
If you ever get confused again go to rock auto and look for a lug nut or a wheel stud. They'll give specs.
Most lugs are either 12mm or 1/2", you can put an open end wrench over and it'll "Just fit". For the thread pitch, lay the wrench on its side-- 1.5mm pitch means 8 threads visible across your 12mm open end.
The lug nuts hex head is 19mm (meaning you use a 19mm socket to get them off) and yes, 100 ft/lbs for the torque spec.
