It wouldn't be the end of the world to go with a heavier oil when towing heavy in warmer temperatures. That said, I wouldn't go higher than a 30wt unless you're trying to use a single oil in your fleet, and other vehicles demand a 40wt.
I'd consider something like the rotella 10w30 or Mobil 1 High Mileage 10w30 in the summer, but I agree to go with the olm, or at least use a used oil analysis and verify 6-mo OCIs. 6 months on a hd 10w30 and 6 mo on a good 0w-20 like Mobil 1 Extended Performance might be a good set.
But in reality it isn't needed. It's only for peace of mind if you're so inclined, or if you do indeed see consumption.
Brake fluid Id do every 24 mo since you're towing heavy, and PSF Id consider doing every 3/36 or 4/48 personally.
