yes, you are right No AC on the base model but the list is huge! It even has a pollen filter! The only way you know it has no AC is to guess from reading this.
Climate Control Options
Heater
Here is the skinny for $17K MSRP
What's Included
Interior
Premium Cloth Bucket Seats
Powertrain
GVW Rating - 4,435 Pounds
Standard Features
Model HighLights
Key Features
Additional Key Features
Deep Tint Sunscreen Glass
Speed Control
Outside Temperature Display in Odometer
Rear Window Defroster
Electronic Stability Control
Hill Start Assist
Electronic Roll Mitigation
Active Head Restraints
Advanced Multistage Front Airbags
Supplemental Side-Curtain Front Airbags
Supplemental Front Seat-Mounted Side Airbags
Sentry Key Theft Deterrent System
Luxury Front and Rear Floor Mats
Variable Intermittent Windshield Wipers
Rear Window Wiper / Washer
Fog Lamps
Black Side Roof Rails
Rear Seat Heat Ducts
Tilt Steering Column
Illuminated Cup Holders
Engine/Transmission
2.0-Liter I4 DOHC 16-Valve Dual VVT Engine
5-Speed Manual Transmission
Multimedia
Radio 130 AM/FM/CD/MP3
4 Speakers
Seating
Rear 60 / 40 Folding Seat
Wheels/Tires
16-Inch x 6.5-Inch Styled Steel Wheels
P205/70R16 BSW All Season Tires
EPA est. MPG
23 city/30 hwy
Interior & Exterior
Additional Features
"Jeep" Badge
"Patriot" Badge
12-Volt Auxiliary Power Outlet
120-Amp Alternator
120-MPH Primary Speedometer
13.6-Gallon Fuel Tank
525-Amp Maintenance Free Battery
Accent Color Liftgate Applique
Air Filtering
Anti-Lock Front Disc / Rear Drum Brakes
Audio Jack Input for Mobile Devices
Black Door Handles
Body-Color Fascia
Body-Color Grille
Brake Assist
Bright Interior Accents
Compact Spare Tire
Firm Feel Power Steering
Flat Load Floor Storage
Floor Carpet
Fog Lamps
Front Dome Lamp
Front Passenger Seat Belt Alert
Full-Length Floor Console
Halogen Headlamps
Height-Adjustable Front Shoulder Belts
Hill Start Assist
Instrument Cluster with Tachometer
Liftgate Door with Fixed Glass
Lower Body Side Accent Cladding
Map / Dome Reading Lamps
No Lumbar Adjust
Non-Locking Fuel Filler Cap
Passenger Assist Handles
Power Accessory Delay
Rear Stabilizer Bar
Rearview Day / Night Mirror
Single Low Note Horn
Sliding Armrest
Sliding Sun Visors with Mirrors
Speed Control
Steering Wheel
Tire Pressure Monitor with Warning Lamp
Touring Suspension
Heater
Exterior Paint Procedures
Monotone Paint
Glass
Solar Control Glass
GVWR Packages
Mirrors
Manual Fold-Away Mirrors
Sound System Components
Fixed Long Mast Antenna
Speaker Systems
4 Speakers
Tires
Wheels
Performance
Engine
Transmission
Safety & Security
Convenience/Security Options
Manual Door Locks
Manual Windows
Dimensions & Capacities
Exterior Dimensions
Ground Clearance - at curb weight - Approach Angle:26.4
Ground Clearance - at curb weight - Breakover Angle:20.9
Ground Clearance - at curb weight - Departure Angle:28.5
Ground Clearance - at curb weight - Running Ground Clearance:8.1
Overall Body Width:69.2
Overall Height:65.5
Overall Length:173.8
Overhang - Front:34.7
Overhang - Rear:35.1
Track - Front:59.8
Track - Rear:59.8
Turning Diameter - curb-to-curb - Left:35.6
Turning Diameter - curb-to-curb - Right:35.6
Wheelbase:103.7
Interior Dimensions
Cargo Capacity - Behind First-Row Seat:63.4
Cargo Capacity - Behind Second-Row Seat:23.0
Cargo Capacity - Rear Seats Folded:53.5
Head Room - Front:41.0
Head Room - Rear:39.9
Hip Room - Front:52.3
Hip Room - Rear:51.0
Leg Room - Front:40.6
Leg Room - Rear:39.4
Passenger Interior Volume:104.4
Seating Capacity - Maximum Seating:5
Seating Capacity - Standard Seating:5
Shoulder Room - Front:54.5
Shoulder Room - Rear:54.0
Trunk Lift-Over Height:30.7
Capacities/Weights
Base Curb Weight - Automatic Trans:3211
Capacity/Weights - Fuel Tank Capacity:13.6
Capacity/Weights - Gross Vehicle Weight Rating (GVWR) :4435
Payload Capacity - Standard:925
Towing Capacity - Maximum:2000
Towing Capacity - Standard:1000
Weight Distribution - Automatic Trans - Front :58.0
Weight Distribution - Automatic Trans - Rear:42.0
Basics
Brakes - Front
isc
Brakes - Rear
rum
Driveline Configuration:FWD
Maximum Number of Doors:4
Steering:Rack & Pinion
Suspension - Front:Ind
Suspension - Rear:Multi-Link Ind
Tires - Aspect Ratio:70
Tires - Construction:R
Tires - Spare Tire Type:Compact
Tires - Type
Tires - Wheel Diameter:16.0
Tires - Width:205
Vehicle Type:Sport Utility
Mobility
Body Opening Width :31.5
Open Door Angle:68
Open Door Trim to Body:28.0
Seat Cushion Height from Ground:26.5
Seat Cushion to Rocker Panel:9.1
Step-Out Height :4.5
Step-Out Width:8.5
Step-Over Height from Ground:17.4
Warranty
Basic - Miles:36,000
Basic - Months:36
Powertrain - Miles:100,000
Powertrain - Months:60
Roadside Assistance - Miles:100,000
Roadside Assistance - Months:60
Rust-Through - Miles:100,000
Rust-Through - Months:60
