So, I'm a long-time BITOGer. Last April, I bought a Chevy Volt. For those who don't know how it works, here's a summary:
The car has a crazy-large electric motor, and a not so large battery. So, for the first 45 miles or so, you're driving an all electric car. The gas engine never even starts up. And, as long as you charge the car before the battery is drained flat, the engine won't start up.
After the battery is drained "flat," then the engine starts up. The engine drives a generator putting power into the battery, and the electric motor takes power out of the battery and runs the wheels.
(This is the short & sweet explanation - there's more to it than this - engine maintenance mode, fuel maintenance mode, and sometimes the engine directly drives the wheels.)
All the while, the Oil Life Monitor is watching the engine (and the calendar) to determine when to change the oil. And, that's the problem. I use the engine so infrequently that I only get to change oil once every two years. This is because I only put a few thousand miles on the engine - I don't put enough miles on the engine to use up oil life, the OLM changes the oil at least every two years no matter how few miles the engine runs.
Since it's a GM car, it uses dexos1 5w30 oil. It's really hard for me to get my BITOG geek going, trying this oil and that oil and this filter and that filter when I only get to change oil every 2 years. And, it's worse because I have to constrain myself to the dexos1 selection of oil.
So, any of my fellow BITOG folks: Don't buy a Chevy Volt. There isn't enough to do with the car to satisfy your desires to play in the oil.
PS - If you have any questions about the car, fire away & I'll do my best to answer them. I was an electrical engineer in my previous life, so I fancy myself to be "smarter than the average bear."
