Here is an interesting article I finally came across in my relentless searching about these crap transmissions.
https://www.motorverso.com/dodge-caravan-shifting-problems/
Symptom #2 especially seems to give me reason to believe that this dealer that did my "REBUILD" was as full of CRAP as the 62TEs with all their problems are.
The dealer invoice on the rebuild said they put in a Torque Converter Kit & 10 Quarts of Fluid, but I know for a fact that they either did Not put in 10 Quarts, or if they did, it was not ENOUGH, because at one point after it started doing the shudder, I checked the fluid and it was 1 quart low, which I put in, and it read FULL after that, but the damage could have already been done to the clutches, since the entire outside of the transmission, engine and frame is bone dry with no signs of any leaks! I also suspect that they used off the shelf Brand New OLD parts instead of the newer REVISED & UPGRADED parts.
