2013 Cadillac CTS oil recommendation
In the shop
Hello and family friend of mine has a 2013 Cadillac CTS. Been using Mobil 1 5w30 and she said that since we are going to North Carolina beginning of October; what oil is good to use in car. I said can't go wrong with Mobil 1. Suggestions, thoughts and advice? She drives 95% highway miles and does very little stop and go driving.
She MUST use a Dexos certified oil. This V6 has a tendency to eat cam chains, a several thousand dollar repair. The Dexos oil was created to minimize this. The Dexos spec is tight, any dexos oil will be good. I believe that engine uses 5W30 and it must be that for the cam phasers. She is also supposed to get software updated for the oil life monitor on some of these.
Rod
I have been using a 10w30 full syn, non dexos non M1 (even though it shows that on the oil fill cap) in my 2006 Caddy CTS 3.6L and nary a problem. Not suggesting anyone else should, but I am not as giggly over dexos1 as some are. It is good, but I don't have an inflated paranoia gland that makes me worry about it.
She already had the update done for OLM. I said "I'd just stay with Mobil 1 5w30 and u could go with Mobil 1 Extended Performance 5w30 if you like"
Anything dexos will be fine
For cars using an OLM, I like to use the cheapest synthetic on sale. This month, it seems to be PP, which Napa has for $4.99/qt, and there's a $2/qt rebate on top of that. Note that you do not need a full synthetic, since a syn blend will suffice (anything dexos1 is acceptable). But there's usually a full synthetic on sale, so why not?
And correct, nothing wrong with M1
Yours was pre-Dexos and many in that era called for Mobil 1 10w30. In a newer Caddy (or any GM) I'd use ONLY a 0/5w30 Dexos oil. Especially with the 5 Year/10,000 mile warranty..
Tiredteucker: I also don't buy into GM's DEXOS thing either. We use a re refined oil aka "Safety Kleen ECO POWER" oil in these cars at work without issue.
I have been using a 10w30 full syn, non dexos non Mobil 1 (even though it shows that on the oil fill cap) in my 2006 Caddy CTS 3.6L and nary a problem. Not suggesting anyone else should, but I am not as giggly over dexos1 as some are. It is good, but I don't have an inflated paranoia gland that makes me worry about it.
That would be true, but my 2013 Silverado 5.3 got 10w30 and my current 2015 2500 6.0 Silverado also gets 10w30, non dexos, though both have a dexos1 recommendation. In fact every thing from my portable generator on up thru my commercial semi truck gets 10w30, though in different classifications... gas or diesel. Have not had a oil related engine problem in 40 years, and I have never had a dealership or OEM shop ever ask what brand or viscosity of oil I was using, even when getting some warranty work. Again, I just don't have an enlarged paranoia gland that makes me worry about dexos1. But that 2006 Caddy CTS did call for Mobil 1 5w30 synthetic, not 10w30 as you stated. Never used Mobil 1, ever. And that car runs as good as ever. Will keep it for a lot longer. It is in immaculate shape and runs great. And this next January, the license plates renewal goes down to $50 for the year because of its age.
What's the point of using 10w30? You live in Iowa, not Florida. Not that it's a huge difference either way, but the DEXOS spec's look solid and you might lose some fuel economy in winter...
Originally Posted By: car51
With the highest bit of respect; I don't think TiredTrucker is drinking the thin oil and licensing stuff kool aid
Not sure [censored] it would be "cool aid". Do you guys have some valid criticism of it? I could give a [censored] less what you use in your car, but why even start this thread or contradict yourself in other threads?
It's DEXOS approved so good enough for GM, good enough for me:)
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4199866/maxlife_oil#Post4199866
If the car has warranty on it, and she is interested in maintaining warranty, and you are interested in her interests, recommend a Dexos 1 oil.
Mobil 1 is not Dexos rated.
DEXOS is something Gm created period. I don't honestly care either, car is out of warranty. Stop being so harsh also.
Um wut? LOL It was one of the first to be DEXOS rated...
Any Dexos syn 5w30 or maybe Mobil 1 Advanced Fuel Economy 0w30...
No authority on Dexos but I'd say this is reasonable. I'd likely favor the Mobil 1 0w30AFE, also currently on roll back at MW to ~$21 a jug. ~$9 after rebate. Just me.
