2013 Acura RDX - multiple warning indicators
Check engine warning light, check power steering warning light, check VSA, check hill brake assist, and multiple others. Extremely rough idle, car noticeably shaking/vibrating.
Car was just in for new spark plugs, state/emissions inspection, transmission fluid service, coolant replacement, and timing belt service.
Mileage is 103K.
Last week was told car was in pristine shape by service department....lol.
Called today and they said have it towed and do not recommend driving it.
Any ideas what's going on?
Maybe a bad ground. My dad had a pickup where it lit up with all kinds of problems. Turned out to be a corroded ground connection.
I had a car that popped up all kind of warning stuff and it came out to be an alternator beginning to fail.
You live in the rust belt? Could be that or a bad ground cable.
Had to break the news to my parent’s neighbor that his 2006 Dodge Cummins needed new cables because of internal corrosion on the cables. If you’re doing one you may as well do them all, power and ground.
