Originally Posted by oil_film_movies
Originally Posted by PimTac
Originally Posted by Jimzz
2 quarts low will add a lot more wear to the timing chain. You really need to check/top off more often.
I'm surprised nobody else mentioned checking the oil level more often.
Good idea to check oil at least once a month. Put it on your calendar if its hard to remember with a busy life, understood.
That said, this engine is wearing well, average iron PPM levels are fine. The oil pickup tube is low in the sump, so its been pumping oil, even 2 quarts down is not that bad. Much more than that could be an issue, but not this engine. Good choice of engine oil here, MaxLife with its titanium protects well.
Originally Posted by tiger862
Mom's Impala 3.6 did same thing on Pennzoil 5w30. It looked like burnt syrup. If I can talk her into it I want to try Valvoline advanced synthetic high mileage in it to help with oil break down and possibly usage. Engine looks clean through oil fill but
suspect carbon on rings which only fix is rebuild. Sad for 124k and it loss one quart last oil change and 2 this time. She had 100k warranty but at 100k only lost one quart between changes.
Wait, before tearing down the engine, try a patented POE+AN+etc. blend specifically targeting carbon on pistons. Ordered at
https://www.ryderfleetproducts.com/valvoline-877377/premium-blue-restore-10w30-gallon-p-vvl-877377 ..... Only use May thru October since it's a 10w cold oil. ....
There have been bitog threads on its efficacy
See
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4778351/1 for details.
I don't plan to teardown engine as she drives 75 miles a day and this is her only car. She is reluctant to try high mileage oil as only one with certification of Dexos is Valvoline and she has ran Pennzoil Platinum 5w30 exclusively with 5k to 7k oil changes. She seems to think maybe she should not have gone over 3k for last 100k and she hates having to put synthetic oil in it.
