Originally Posted By: OtisBlkR1
With my intention of 7-10 years of keeping it and under 200,000 miles till trade in, im figuring Engine oil every 7,500 (full syn) and I will do 3-4 quarts of DW1 every 30,000 and the transfer case and diffs every 50,000 (unless the factory schedule calls for something else) I haven't looked it over yet.. this is just guessing off my hip however I think those are pretty safe suggestions.
Acura recommended VTM-4 fluid service intervals of 30k miles (with the first at 15k). I don't know about the models with the SH-AWD system...so do check that.
I used to do 30k mile intervals, but moved that to 25k because it's divisible into 100k, and I can always stay on the same miles checkpoints dropping the hundreds digit. 75k, 100k, 125k, 150k, etc.
OH, well good call on the VTM fluid.. ill go that route then.
Actually you have to buy Acura only Acura Dpower steering fluid fluid which is specific to SH-AWD. The front diff uses normal gear oil. I use the oil life monitor to tell me when to change those things.
