Originally Posted By: oil_film_movies
Something got in there. Reminds me of the cascading engine failures triggered by debris in the recent Corvette well-publicized problem:
"After bringing it back to Chevrolet HQ for inspection, the engineers determined that the likely cause was a piston connecting rod bearing that was damaged by debris in the oil that was left behind after tapping the threads for the oil filter. Once a piece gets jammed in there, it starts creating more debris, which keeps making things worse until finally … kablooey. In this case, it took out a few more pistons with it." http://www.foxnews.com/leisure/2015/08/2...engine-problem/
Here's their recommendation: Several other engines built early in the production run exhibited similar problems, but Chevy is confident that it has solved the root issue. Nevertheless, it is now recommending that all Z06 owners change their oil after the 500-mile break-in period to make sure that it’s clear of any debris before any of it gets stirred up into the important parts during high-performance driving.
A mfg. recommending an early OCI.
