2010 Ford Ranger
3 days behind the wheel. I haven't had this much fun in a long time :)
Ended up with a pretty loaded sport, not the XLT, but the rest of my original description is the same.
Initial impressions: (Keep in mind v6 4x4 stickshift we're talking about, the 4cyl and autos I can't speak for besides 1 test drive seeming way too underpowered)
-4.0 motor is plenty powerful for this truck. Haven't hauled anything heavy yet but it just rips empty, even at lower RPMs. Has a great sound to it when you put it to the floor at midrange, beautiful growl.
-Definitely "rides like a truck". More comfortable than my old beater by a longshot but you do get bounced around pretty good driving over train tracks, speed bumps and shredded roads. Never feels out of control, but no luxury smooth ride here.
-Controls are all idiot simple and obvious, you'd figure everything out in 30sec without ever looking in the manual.
-Manual transmission pops into all gears quite nicely. Gearing is great, low enough to get going quick and 5th is high enough for the highway. You can feel the engine vibration through the gearshift stick sometimes though, must be a direct linkage.
-Electronic transfer case jumps from RWD to 4WD fast and easy. 4WD on dry roads is a no-no though, you can hear the tires complain a little while turning. Manual recommends against it. Kept that experiment brief. Supposed to get some snow tomorrow, if so we'll see how it works for its intended purpose.
-Simple for sure, but quite adequate interior as long as you're not expecting Cadillac comfort. Visibility is great, I've driven a little subcompact car for years and I had no problem backing the Ranger in or parallel parking on the first day. I've struggled more with full size sedans.
All in all, has a simple, very solid feel to it. Looks great too IMO. Devoid of anything fancy, but that's why it caught my eye in the first place.
Will update again later. Thanks again for all the input to everyone who's replied.
Great little trucks,the 4.0 v6 still uses 5w30 because it has 4 timing chains 2 in front and 2 in back,with regular maintence will last for many miles,to my knowledge only ford that uses 5w30,they will get 19-21 mpg highway and have around 210 horsepower.I have had a 1999,2003,and currently have 2005 with 3.0 v6, they are pretty low maintence
Sounds like you got exactly what you were lookin for - a solid pickuptruck with a long track record. So long as you aren't expecting it to be a car, all should be well.
One common gripe - don't expect much better gas mileage than a full size truck with the 4.0. It has never been a real fuel miser, but does well enough. I've got one in my Explorer, its never broken 20 mpg (thought its seen 19+). My full size F150 with the 4.6 delivers similar freeway mileage, though it suffers with City driving.
Yeah, it definitely seems to drink the juice down readily. To be fair, I'm going to get a couple thousand km on the clock and spring to start before I start saving gas receipts and calculate exactly, but I don't expect a drastic improvement. We finally had some snow here (right after I bought the truck of course) so I've been running around in 4x4 mode a lot. Winter gas still too, of course. But once again, I don't expect a huge improvement. I had a pretty good idea what I was getting into buying the larger motor.
I have no regrets there, though, I drove my sluggish little econobox for years and it is very nice to have passing power and hauling power finally. I have a fairly short drive to work and if I don't go much of anywhere else I can easily squeeze over a week out of a tank.
4x4 or not though, this truck would benefit from a set of winter tires just as much as little cars do, maybe more. No problem getting going on snow/ice with the 4x4 but pretty slidey. Haven't driven a winter without the proper tires since my first year driving and now I remember why. Will definitely have to budget that in for next winter.
Congrats on the purchase! I love my Ranger. If I wasn't a Courier, I would've sprung for the 4.0, but I do like the 2.3. It has OK power(improved after break-in), plus I average nearly 26mpg.
Good luck w/ the truck, any pics?
Even with the 4x4, it doesn't hurt to put some weight in the back. In my F150 4x4, I add 140-210 lbs of sand tubes in the bed. Keeps the "squirrelyness" to a minimum. I tried wiithout them, and it worked with the 4x4, but just feels more secure with the tubes in back. Extra traction in a pinch too if I needed some sand!
congratulations! I had a 96 ranger with the 2.3 great truck! Enjoy! Pics?
Thanks guys, no pics for the moment as I don't have a working digital cam, but I'm def looking to get some pics of it once I can borrow one. Will put one up then.
