Hey guys,
I read a sticky on here that says you may be able to give me some suggestions for what type of oil to run in my 2009 STI? I had just purchased it with 90,000 kms on it.
I will be running the OEM filters, and the manual calls for 5w30.
I had looked on STI sites and the posts shows that everyone runs different oil, amsoil, RP, Mobil 1. you name it.
I live in Vancouver, BC, the temperature here ranges from -10 Celsius in the coldest of winters to 30 Celsius on a hot summer day.
I drive from home to work and back every day, make trips to errands in around 40 KM legs, with lots of rest in between usually. I would say I drive an average of 50KM a day.
About half of that is in traffic condition, but not really stop and go condition, more like limited to 60km/h driving and with frequent stops for lights.
I like to drive the car kinda hard, but I RARELY go above 4000 RPM. I have my shift lights set to 4000, and I will usually shift before it goes off. Definitely no track stuff!
I am wondering what weight of oil to run? I read most of the Oil University stuff, but still don't know what oil I should be running to avoid excessive engine wear during cold starts.
I try to let the car idle when first starting for about 2 minutes or more, then will run very lightly (under 2000 RPM) until the engine (coolant im pretty sure) temp goes to normal operating condition.
I do not have a target for gas consumption, and I would probably change my oil and filter every 5000KM anyways even though people tell me that synthetic can run for longer.
people have told me the STIs like to drink oil, but mine seems to be doing fine on 5w30 Liqui Moly synthetic oil. (from a mechanic when he changed my oil last, about 2000KMs ago)
I do not know this brand of liqui moly, and I would like to look into alternatives anyways (cheaper is good always!)
I am looking for a brand of oil and a weight to go with, i read that I should be aiming for a lower weight oil, then people say the low weight will shear easily and become even lower weight oil. (but isn't this a good thing? because you want less viscosity at lower temperatures anyways according to the oil university source on this site)
people on other sti forums say that I have to find a oil that works for my engine, because everyone seems to find ones that work well with their car. So I guess I am more concerned with what weight to aim to get for my running conditions with the car. any suggestions on the brand would be nice too!
anyways, sorry for the long post, I just want to find a good oil! Cheap is always an up if it doesn't cost me an engine eventually!
Cheers,
Peter
P.S. let me know if you would like more information to help with making an oil decision!
Cheers,
Peter
