Originally Posted by SatinSilver
How did it go when contacting corporate about the clunk in the back?
I assume the humming is the coupling, but it is very slight, mostly noticeable from 25-35 MPH. It is most likely the coupling, but it still could be a wheel bearing. I was going to wait to see what happens with the oil. If the consumption reduces with the PCV valve, then I'll consider forking over the $100 to the dealer for diagnosis to see if it is the coupling, and if Toyota is in the mood for some goodwill. If not, we may just run it as is for another year or so then get rid of it. I'm sure it can hum for quite some time. If it gets bad, I'll just pull the driveshaft and rear axles to disable the 4WD--a free fix!
