My Mom's Fusion has been losing coolant for awhile now. Not at a huge rate, but a "new" car losing any coolant is not normal. One of the first things I tried was to switch the cap between her car and mine as they are the same. That did nothing as my car still does not lose coolant and hers still does.
Well, today I took it out to fill it for her. When I got back home I popped the hood to do my underhood checks before she leaves for Spokane tomorrow night. I could hear the coolant cap bubbling as soon as I did so. I play with the cap and find I can reduce or increase the rate of pressure loss by twisting it.
So I take it completely off and look at the cap. It appears fine and since this is cap #2 that is leaking I doubt it is bad anyway. So I take a close look at the tank where it is supposed to seal and BINGO! The sealing surface is flat from the outside edge until the outer perimeter of the internal opening. At that point, there is a small half-round bump approximately 1mm high by 1mm wide. There is a portion that is dented to the point it is even with the flat portion. I believe this is the fault. Any good ideas to get it to seal? I was thinking either A. Take the whole half round off by sanding it or B. Putting a dab of RTV at that point. I would just have to replace the RTV every time it is removed. Which, once it is sealed should be but once every few years.
What do you guys think?
