Going back to TBN, I forgot to look at PQIA, so thanks for the reminder. The only other comment is regarding the method of testing. There are two TBN tests common to test labs, ASTM 2896 and ASTM 4739. ASTM 2896 will read about one unit higher than 4739 on the same sample. ASTM 4739 is often preferred for used oil, but labs can use either. The oil companies Data Sheet listings are almost always ASTM 2896. So, if one PQIA used 2896 and the used oil analysis lab used 4739, you can bump one up or one down to get a closer comparison of starting vs ending TBN.
Oh, and Dave, thanks for pointing out that little cost fact. When you consider a 7-7.5K run on an OC that cost $19... and a used oil analysis that good.... why it's enough to make a Scotsman jig for joy!
