2008 Suzuki S40, Initial Fill, 59 miles
OTTAWA, ON, CA
Code:
Sample Date 28-JUN-2008
Analysis Date 14-JUL-2008
Lab Wearcheck Canada
Make Suzuki
Model S40 LS650
Year 2008
Engine 652cc SOHC 1cyl
KM 95 (59 miles)
Oil Brand Dealer Initial Fill
Oil Series NR
Oil SAE J300 10W40
API SX NR
KM on Oil 95 (59 miles)
Time on oil 2 days
Antimony Sb NR
Cadmium Cd NR
Vanadium V 0.3
Aluminum Al 11
Chromium Cr 1.3
Iron Fe 27
Copper Cu 13
Lead Pb 2.1
Tin Sn 1.2
Molybdenum Mo 317
Nickel 0.0
Manganese Mn 2.6
Silver Ag 0.2
Titanium Ti 0.2
Potassium K 1.9
Boron B 147
Silicon Si 32
Sodium Na 3.5
Calcium Ca 2310
Magnesium Mg 19
Phosporus P 1049
Zinc Zn 960
Barium Ba 14
Sulfur 6809
cSt @ 40 C 85.6
cST @ 100 C 13.8
SUS @ 210 F NR
VI 165
Flashpoint (F) NR
Fuel %
Antifreeze % NR
Water %
Insolubles % NR
Sulfation 36
Oxidation 26
Nitration 12
TBN (IR) NR
TAN NR
Ferrous Debris NR
Soot % NR
Glycol
ISO Code NR
Additives NONE
WHITE METAL VLITE
Notes All component wear rates are normal.
Location ON, CAN
Air Filter Suzuki OEM
Oil Filter Suzuki OEM
Sunruh, I cant remember if I asked you this a while ago. What are you using for your main oil? Or do you still test different oils?
I think you said a year or so ago (i believe) that you were extremely happy with Exxon Superflo 20W50. Then later that you also liked Supertech 15W40.
Just curious if you have found an oil or two that are your 'go-too' oils.
