Hi all, a few weeks ago my idle got weird like I was going to stall out and it eventually started to overheat. It ended up being a loose fan cable connector as nothing else was found. Since then I changed the oil about a week ago. I noticed lately that when I come to a stop it gets shaky and rpm rises up a bit (back and forth). A very small variation but not like it usually operates. I get the impression it is somehow linked to my previous issue but cant prove it, as my car does not overheat now. I cleaned the throttle body and maf sensor in november so I dont think its that. No engine codes, no other issues. Just curious what easy things I can check/replace first. Thanks in advance. I will probably clean the TB again as a first step but I doubt 3000km of driving would cause that issue. Could it be a coolant temp sensor? A fuse? I have no idea.
