Issue appears to be an out of balance driveshaft; Once in a while, the shifter (MT) i feel a wobble and the vehicle bobbles at high speed
Several months ago, i did a panic brake and slide on a wet sandy state highway and I think the issue started then.
Today I'm under the vehicle and I see the issue; right behind the 5sp MT there is a large metal collar which is supposed to be attached to the DS which has broken loose and it just hanging on the DS. Looks like it is supposed to be press fit on the DS over some rubber donut piece.
That explains why when I stop quickly, I hear a clanking noise, the vibration disappears. The donut is slipping onto the yoke of the MT.
Why is there a 20lb slug on the DS. I assume this is for balancing, does that mean it has to be balanced in a particular orientation or is it just for vibration mitigation?
Pretty bad design, wondering what I should do to fix. Can I just glue the donut back on? What would I use?
Thanks.
-Thomas.
edit:this is it; seems like a common issue.
https://www.google.ca/search?hl=en&q=ford%20ranger%20drive%20shaft%20damper%20yoke&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41248874,d.dmQ&biw=1280&bih=687&wrapid=tlif135899713592941&ie=UTF-8&sa=N&tab=iw&ei=p6YAUfe4IYT90gGh_4BA
Thanks.
-Thomas.
