Hello BOTIG! Been lurking around for a bit, but here is my first post!
I needed a new daily and i ended up landing on a ford ranger. I live on a farm which is a 12km trip down a gravel road to get to, so i needed something that was going to be rugged, practical, kind of a beater, but something that still runs good and that i can get parts cheaply for.
I bought this 2001 ranger for cheap knowing fully well about the timing guides on these engines...issues are not an issue if the price is reflective of it.
There are two kinds of ford 4.0L SOHC V6 engines-those that have had the timing guides done, and those that need the timing guides done. Doing the guides is 100% an engine out job. No getting around it.
You will need a space where you can thrash on your truck for a couple days at the minimum-i took a full weekend, plus a full week of wrenching every evening after work. There is a lot of hullabaloo to deal with to get the engine out but with some patience and grit, even an amateur like me can do it.
This dude on youtube made a very helpful video on doing the guides on this engine.
Most of the engine gaskets were leaking, so it was greasy messy work, so i diddnt take too many pictures. I changed just about every gasket and seal that i could while i had the engine out.
There is supposed to be a timing guide there!
Got half of it.
The other half was kept by the retaining bolt, which is behind the flex plate, hence the need to remove the engine from the truck.
The rest of it was in the oil pan. I ended up putting it back together like a puzzle to make sure i had every last bit out of the engine.
New cloyes guide installed
The front guides were still OK but I changed them too, along with a new water pump and fluids changed.
Truck has been flawless since i did this about a year and a half ago. Took it on a 3,000 km trip to visit my hometown and it never skipped a beat. It is my daily to get me to work. Fuel mileage isnt great but its still cheaper than a new car payment!
Got half of it.
