2006 Ford Escape Transmission Fluid
Canada
I am planning to do a transmission fluid change and trying To decide what transmission fluid to use for my Ford escape 2006 xlt 4x4 with the cd4e Transmission. I have heard that you can use Mercon V with these transmission's.
Would this generic Mercon V fluid be ok?
http://www.canadiantire.ca/en//pdp/moto ... 1529p.html
or should I use a mercon/dexronIII like what it says in the manual and dipstick?
http://www.canadiantire.ca/en/pdp/motom ... p.html#srp
Thank You
That trans takes Mercon V, not Mercon/DexIII. Make sure you get the Mercon V stuff... Or at least another branded fluid that clearly states that it meets/exceeds Mercon V specs/requirements.
Amazon sells a 5-quart jug of the Motorcraft Merc V stuff for about $32. Otherwise, I know Walmart sells a Mercon V fluid too.
