J juca Joined May 30, 2020 Messages 2 Location Las Vegas May 31, 2020 #1 Found coolant leak at the water inlet/thermostat housing (valley) plate. Does anybody know what is the bolt torque is for the plate? (there's no gasket, just calls for FIPG silicone form a gasket)
C clinebarger Joined Dec 19, 2013 Messages 9,697 Location Fort Worth, Texas May 31, 2020 #2 M6 x 1.00 bolts like @ 86 Inch Pounds or 10 Newton Meters
The Critic Joined Aug 30, 2004 Messages 35,354 Location CA May 31, 2020 #3 Be sure to also replace the knock sensor sub-harness!
michaelluscher Joined Oct 7, 2012 Messages 6,044 Location Staten Island, NY May 31, 2020 #4 Out of the 2006 Camry FSM I can give you more pages if need be
J juca Thread starter Joined May 30, 2020 Messages 2 Location Las Vegas May 31, 2020 #5 Thanks bros. For the info. You are the best!!!
michaelluscher Joined Oct 7, 2012 Messages 6,044 Location Staten Island, NY May 31, 2020 #6 Originally Posted by The Critic Be sure to also replace the knock sensor sub-harness! Must it be Toyota OEM or is Dorman sufficient? I'd ask how can they screw up a 4 pin wiring harness, but this is Dorman Maybe wrap it in some aluminum tape?
The Critic Joined Aug 30, 2004 Messages 35,354 Location CA May 31, 2020 #7 Originally Posted by michaelluscher Originally Posted by The Critic Be sure to also replace the knock sensor sub-harness! Must it be Toyota OEM or is Dorman sufficient? I'd ask how can they screw up a 4 pin wiring harness, but this is Dorman Maybe wrap it in some aluminum tape? Your guess is as good as mine.
C clinebarger Joined Dec 19, 2013 Messages 9,697 Location Fort Worth, Texas May 31, 2020 #8 Dorman can screw up an Anvil with a glass hammer.
