Originally Posted By: tinmanSC
Yeah, it happens. Replace the hose. It's normally 3/8th inch line. You can get it at most parts stores. It's a simple swap out of the transmission cooler line. I've done it a few times on different cars.
This small section is put there so as the engine/transmission move, it doesn't put any strain on the radiator, fittings or the metal pipes. So, this flexible section moves around a bit. Sometimes that causes cracking and messes with the crimp. You can get new clamps for it too, sometimes they weaken and don't make a good fit anymore (I've only seen this once, however. )
Will a hose clamp put around the crimped section stop the leak, or is replacement the only option??
