2005 snapper 21in walkbehind blade confusion
Coastal South Carolina
Blade replacement time I use my mower to cut a 100 x 100 ft subdivision house lawn- st augustine grass . Also I have a vacant lot 100x200 that the grass grows deep on as I only cut it 6 times a year- lawn type is weeds hee hee. the manual lists 3 blades - a 2-6691 standard lift blade - 1-7168 mulching blade and a - ninja blade. the mower has a side discharge attachment, and also a "recycling mulching" attachment which just blocks off the side discharge. It came with a ninja blade- they are more expensive. If I buy a standard blade and use the mulching plate will I get any mulch effect or do I need the mulching blade too? whats the ninja blade about?. I tried mowing the vacant lot with the mulcher plate on and it was grim - too much grass, so I now use the side discharge chute on the vacant lot - that works
VA
I have the mulching blade on mine but still generally use the side discharge chute... If mulching I just block the chute and have at it, but unless the grass is still fairly short my old 3.5Hp Briggs couldn't do the job... I haven't tried mulching since I installed the 5.5Hp Honda but the difference in power is night and day, might be worth trying just to see how it performs now...
JTK
Buffalo, NY
I'd just bolt up a regular, low-lift mulching blade in place of the ninja blade if that's what you want to do. I've got a 21" Snapper Commercial self-propelled (ninja) mulcher. Mine won't clump or stall, but it will lay over real high stuff instead of cutting/mulching it. The ninja blade is crazy loud too. Mine does blow a bit of clippings out the left side which is annoying, but you could literally bury the mower in a pile of dry leaves and it will powder them up with out even being close to stalling the engine. Joel
edwardh1
I ordered a mulching blade made in the USA by oregon, it was about $8 more than an ace hardware blade thats made in china. all you know about the $15 china made product is that it is metal. has black paint and comes in a carton labelled mower blade.
