ls1mike
$50 Site Donor 2026
So verified, this 2005 had plastic gaskets. Intake has never been off, 130,000 miles. Took me a little less than 4 hours start to finish with 30ish minutes to eat and feed my kids.
Looked pretty decent in there, but the plastic gaskets were done. I replaced the upper intake plenum as well, didn't need it but a GM one was under 100 bucks.
Used the Fel-Pro metal framed intake gaskets.
I think it was like 30 fasteners total. I used 8mm, 10mm, 13mm, and 15mm sockets/wrenches.
It is one of the easiest intakes to replace. I think I am 300 bucks in the repair with new plenum.
Here you go.
The passages filled with grime/dirt dead head to the bottom of the intake, so
all the ones I have done have a bit a build up there.
Here you go.
