Wife drove the van, 2005 Nissan Quest VQ35de, 4-spd automatic 93K miles,on highway.
According to her, she used the cruise control at speed around 70 miles and all of sudden, the engine made hugh noise, then RPM went to red zone, wife cancelled the cruise, the car lost power and pulled over.
When she pulled over, the green coolant are all leaking on the ground, some smokes come out of engine bay. The temperature gauge is in normal range. We had tow truck and got the van back home. I tried to start the engine. Engine started and made huge noise. Then I tried to shift to D, van did not move at all. Coolant still dripped at the time.
What could be the problem? How much would cost? I suspect the water pump failed, timing chain faild?
Please share your wisdom. Thank you.
