2005 impala cluster question
chicagoland
I will be having my cluster repaired with BETTER steppers soon due to temp gauge failure starting but, can I upgrade the cluster with the oil pressure gauge on other impala's ? 2005 impala base. 3.4 v/6 is what I have and it runs soooo smooth and quiet ya would think it's not even running when you come to a stop it's that quiet. 60,500 miles.
OH. Just had all the fuel lines/brake replaced due to being rotted with the winter salt here.
Need to find a deck lid in 812k gray paint color. I dented mine...whoops !!
Yes it will work, but if there's no sender it won't register oil pressure. I've heard mixed stories. According to this thread you need to change the oil sender to one from a 3.8
http://www.impalaforums.com/chevy-impala...e=1497762700518
You should try to find one from an impala or Monte Carlo SS, they should all work except for the boost gauge.
I have a regal cluster in my Century because the stock cluster doesn't even have a tach!
