2005 honda element sludge on drain plug
Originally Posted By: rszappa1
Honda does not reccomend flushing the transmission with a machine...just the drain and fill method....
Ford states the same thing.......
An acura tech friend of mine informed me the reason for Honda stating no transmission flushes was that most of their transmissions have an internal filter/screen and when a flush chemical is introduced the accumulate junk can really create a nasty scenerio inside of the transmission which often leads to failure.
That being said, a fluid exchange through the cooler line should do little to disturb the internal screen. I have perfromed countless fluid exchanges on honda/acura vehicles will only positive results. When will this old wives tale reagarding straight trans flushing finally die?
Here is a link to the Honda bulletin that clarifies how to perform the AT drain/fill procedure:
http://www.in.honda.com/Rjanisis/pubs/SN/A080100.PDF
"NOTE: The term “flushing” refers to repeatedly draining and refilling the trans with Honda Genuine ATF-Z1. Don’t confuse it with aftermarket flush systems. American Honda still strongly recommends that you avoid using them on any Honda vehicle."
