The 2005 Uplander in my signature has an oil leak. It started maybe 2 or 3 oil changes ago...so less than a year ago. It has the GM 3.5 60 degree V6. The oil pan is coated in oil on the bottom, and it flings up and covers the transmission pan in oil as well. It hasnt started to drip on the ground yet. If you are on the ground, and look up the front of the engine up toward the oil filter, there is oil running down the filter as well. I dont think its the filter though because the last 3 filters have had oil dripping down them. So I am guessing the leak could be further up the block? Not sure. I have Castrol EDGE 10w30 EP in it now, it will be changed in another 3 months or so, and I will go with a 5w30 high mileage. Either Max Life, Mobil 1 High Mileage, or QS defy. Not sure yet. Do any of you have this engine, and have this issue? What do you think it could be? Only has 114K on it. Looses about a quart every 3-3500 miles.
