Originally Posted By: Drew99GT
Originally Posted By: silverrat
Originally Posted By: addyguy
Transmission should be the same 4-speed unit as used on others, like mine. It's a sealed unit, so the only way to service is through pan drops. However, it is fairly sturdy, and with even minimal maintenenace will go for a long time.
You can service this transmission by draining from the transmission check plug with the engine off and refilling from a cap near the air cleaner box. You can do that a couple of times.
Can you or someone else corroborate this? Draining the trans through the check plug? Is it easily accessible? How much fluid drains out?
Yes, and it depends...
And it being sealed, I find it better to just do a flush and fill.
I changed the wife's at 52k, and it looked pretty rough....
