Hi -
I have a 2004 Sequoia that is new to me 15k ago. It has 155k on it. The last oil change I put Mobil 1 Extended Performance 5w30 in it and plan to go 7,500 miles. I noticed recently (6k into the oil change) that there is a slow leak at the oil filter (also an Mobil 1 filter). I've tried tightening with a filter wrench and can't get the leak to stop. The oil level is relatively stable. Should I go the rest of the 7,500? Should I go further on this oil change?
Second question, I replaced t-case and rear diff with Mobil 1 75w90 but couldn't do front diff cause I stripped the drain bolt. The mechanic I brought it to replaced with Valvoline Syn 75w90. I was planning to change all three again at 15k due to some towing I do throughout year (camper and raft/trailer). What's your take on 15k oil changes Mobil 1 vs Valvoline Syn?
