A friend of mine recently acquired a 2004 Wrangler with the 4 liter 6 cylinder engine. This engine has 270,000 miles on it. I believe suggested oil is 10w30. With this many miles would 10w30 still be the best oil? Climate is central NY where temps range from well below zero to mid 90s. This vehicle will be used occasionally and not driven hard. He plans on changing AT fluid, T case and diffs also. Engine leaks oil and plans are in place to replace oil pan, valve cover and rear main seals. Thanks for any suggestions.
