There have been a lot of Honda transmission failures in the Odyssey. I'm getting a very quiet whine out of my transmission, but it's been there with no increase for the last 20K miles. There is 43K on the transmission now. The dealer says he suspects that it's a bearing. He gave me the option of getting a rebuilt transmission, which I didn't take. Why? In some cases the rebuilt transmissions fail within 15-25K. I figured if I took care of this one, I'd be better off.
I figured this was the best place to help me figure out what to do/not to do. (Thanks in advance.)
1. Should I start with an oil analysis?
2. What do I need to do to get this transmission to last? Change fluids often? Use a diffferent fluid? Use a used oil analysis? Put on a transmission cooler?
3. Should I consider a different fluid than Honda's ATF named Z1? I want to use something that's proven to be OK. I did change the ATF at 36K miles, which was 8K ago.
4. There is a transmission filter. Should I change that now? It's supposedly a lifetime filter, but many joes are changing it.
The issue with the Honda transmissions appears to be:
QUOTE
The five-speed models typically were damaged by premature wear of the third-gear clutch pack. As the clutch friction material abraded, it scattered bits inside the transmission case, clogging fluid lines and causing erratic shifting.
Why does Honda insist on such an odd design for their automatic transmissions? Most use planetary gear sets and brake bands, but Honda continues to insist on building it like a manual transmission converted to an automatic, with 3 shafts and clutch paks standing in for gears sliding along the shaft for engagement.
UNQUOTE
Thanks,
Dan
QUOTE
UNQUOTE
Thanks,
Dan
