2004 Aveo Transmission oil change.
ON, Canada
My Chevy Aveo is supposed to use Type IV transmission fluid. All I can get at the moment is type VI. I know this is supposed to be compatible but the transmission was made by Daewoo in Korea. Does anyone know if I can still use Type VI. I cant seem to find any more info on the web. Any help would be appreciated....thanks
The Aveo has always used an Aisin-Warner 4spd auto, which is a great thing! They're tops in the AT department IMO. It's probably got a drain plug too. If it specs Dex IV, Dex VI can be used. Nothin' special about Dex 6 other than it's spec'd a long life, "lifetime fill" ATF.
Joel
Aisin is a good trans. Im not too sure about the compatibility between type 4 fluid and the new dexron 6. From what i understand the type 4 fluid is a toyota fluid. The dexron 6 of course is backwards compatible with all previous DEXRON fluids,,im not sure if its a replacement for type 4 as in my dealership dex 6 and type 4 come in different bottles.
That is actually T-IV it is calling for, a Toyota fluid type different from the Dexron fluid series. GM would also carry the T-IV fluid as part no. 88900925 for U.S./22689186 for Canada but at least in the U.S. it is usually about 1/2 price to just buy it from the Toyota dealer.
Bingo, if it's asking for T IV transmission fluid. this is the toyota T-IV transmission fluid that I use in my "Pontiac" vibe auto trans. I wouldn't put D-VI. Put T-IV only. dealerships will have the stuff. make sure you tell them it's for a Chevy Aveo or they will sell you the D-VI
And, any universal or multi-vehicle ATF, that mentions the T-IV spec will work great.
