2003 Tahoe 4l60e sloppy 1-2 shift
Originally Posted by clinebarger
Originally Posted by LeakySeals
I thought the corvette servo made the shift crisper, not smoother?
If you simply throw a 'Vette/093" into a trans that's.....
1. Not calibrated for it.
2. Has loose/excessive Band clearance
The 1-2 shift will definitely firm-up....
What I'm outlining is a complete hydraulic re-calibration of the 1-2 shift!
Can we buy a used valve body, perform the upgrade, hot swap? Can the valve body with this upgrade be purchased somewhere?
I haven't covered any Valve Body modifications up to this point, The only component in the Valve Body that influences the 1-2 shift feel is the Accumulator Valve, Spring & Bushing, This component controls the opposing pressure applied to the 2nd & 4th Accumulators. I was going to cover the that....But this thread will likely die as it involves actual work.
Please keeping going. Don't stop!!
