2003 Pontiac Vibe used as a taxi
current odometer: 215,000km
80% city driving with extended idling
Esso XD3 0w30
km on oil: 15,000km (9300 miles) and 2 months
make up oil: 1L
oil filter: Amsoil
Air filter: Toyota/Denso
First column: Mobil 1 SS 5w30 15,000km
Second: XD3 10,000km from last year
Third: current XD3 UOA
Fourth: XD3 VOA
Tin 0 0 0 0
Lead 6 4 7 0
Copper 0.7 0.9 1 0
Aluminum 2 3 3 1
Silicon 24 10 30 3
Iron 16 10 19 5
Chromium 0.7 0.8 1 0.4
Silver 0 0 0 0
Zinc 950 1200 1450 1350
Magnesium 150 17 11 10
Nickel 0 0 0 0
Barium 0 0 0 0
Sodium 12 13 11 1
Calcium 2000+ 2000+ 2000+ 3800
Vanadium 0 0 0 0
Phosphorus 856 1050 1300 1300
Molybdenum 80 6 2 0
Boron 60 4 0 3
Manganese 270 97 341 1
PHYSICAL PROPERTIES
Viscosity @ 100ºC 12.48 12.26 13.80 12.07[XD3 VOA]
Water 0 0 0
Solids Glycol No No No
Fuel Dilution No No No
OTHER PROPERTIES
TBN 7.45 7.38 7.34
Oxidation 33.05 16.38 28.57
Nitro Compounds 0.00 3.24 11.62
Organic Nitrates 53.33 37.90 57.62
Well, here you can clearly see the effects of city driving and extended idling in dusty conditions with a hot running I4. The lab lists oxidation as "moderate" and nitration as "severe". It's definitely the end of the line for this oil. Silicon was also flagged as high. I thought I had that licked last time when I switched back to OEM Denso air filters but apparently not. My town is just dusty and there's not much I can do about it.
Iron is up slightly likely due to dirt ingestion, but everything else is very good. This is the OCI I have been using with XD3 for the past 10 months or so. Maybe I'm pushing the limits a bit but I don't think it's going to shorten the engine life by any appreciable amount. I'm going to start putting grease on the air filter seal because it's a hard plastic with a sealing groove rather than foam or rubber.
P.S: the TBN numbers look funky but it's easily explained. The 10k OCI had no make up oil. The 15k OCI had 1L added around 11k.
Esso XD3 0w30
make up oil: 1L
oil filter: Amsoil
Fourth: XD3 VOA
Tin 0 0 0 0
Lead 6 4 7 0
Copper 0.7 0.9 1 0
Aluminum 2 3 3 1
Silicon 24 10 30 3
Iron 16 10 19 5
Silver 0 0 0 0
Nickel 0 0 0 0
Barium 0 0 0 0
Sodium 12 13 11 1
Vanadium 0 0 0 0
Molybdenum 80 6 2 0
Boron 60 4 0 3
PHYSICAL PROPERTIES
Water 0 0 0
OTHER PROPERTIES
TBN 7.45 7.38 7.34
